Discussion topic: Sky reception has gone down for past 2 days
This message was authored by: DaveBos
We want our sky reception restored
Re: Sky reception has gone down for past 2 days
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
What happens when you try to watch Sky?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for DaveBos
No Satellite Signal shows up.   Checked dish, cables.  Recycled power etc.
Still the same.  Lock indicator shows NOT LOCKED.
Most likely a dish/cable problem. Unfortunately Sky no longer provide engineer support for Sky+ boxes unless you have Sky Protect, so you'll need to engage a local satellite installer to come and take a look.
Alternatively if you upgrade to Sky Q, your dish setup will be examined and any issues put right at no additional cost to you, as part of the Q installation.
