The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
11 Oct 2018 06:30 AM
Thank you so much, was having a nightmare last 4 days trying to sort this, gave up many times waiting in a q for sky tech help. Found your post and followed your instructions and' hey presto' we are working again. 😀😀
24 Oct 2018 01:46 AM
Thanx Annie it worked a treat . Full service is restored 🤗🤗🤗
@Annie+UK wrote:
@sim+sky wrote:This is happening to us too. I’ve rebooted, reset, checked connections and as our WiFi IS working for everything else in the house, why Sky only?
We pay for Sky Protect, the little WiFi connector on our box says it’s got WiFi so I’m fairly confused
Routers are a science all to themselves, just because they are working for 99% of all devices does not indicte that the router is not the issue 🙁 It is always worth rebooting the router as it will do no harm
try disconnecting the Wi-Fi physically from the Sky Box then power it of at the mains for at least 5 minutes then turn it back on, wait another 5 minutes for it to fully come back on then reconnect the Wi-Fi adapter
24 Oct 2018 08:14 PM
OK so on the Network settings it is showing as:
Connection to Broadband Router = OK
Connection to On Demand = FAIL
IP address is showing, good signal strength,
I've tried resetting Router, powering off Sky Box (switching off power) and powering off/on the wireless box. Still showing Connection to On Demand as FAIL.
Any ideas?
24 Oct 2018 08:21 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried @Annie+UK's suggestion below?
24 Oct 2018 08:40 PM
Yup, powered both off (disconnect from mains) powered back on still connected to wifi but not to On Demand .
24 Oct 2018 08:45 PM
Posted by a Superuser, not a Sky employee. Find out moreDid that include physically disconnecting the On Demand wireless connector from the Sky box, not just powering off which is what I think Annie was suggesting? That has worked for me in the past.
08 Nov 2018 07:29 PM
Hi, I’m having the exact same problem. Box is showing as connected to router but fail to on demand. I’ve followed all of the instructions shown in the posts above & I have also tried 2 different sky+ boxes. 1 has an external wi-fi connector (same as the photo in the earlier post) & the other is wi-fi enabled. I’ve tried to connect via WPS & with password all with the same result.
09 Nov 2018 05:51 PM
what does the on demand connector look like??
09 Nov 2018 05:53 PM
Have a look on the sky store website
09 Nov 2018 05:59 PM
Thanks, it appears that as I have a WPS button I didn't require a connector
15 Nov 2018 06:06 PM
Have tried all the suggestions with no luck. My On Demand box is connected with a Cat 5 cable to my Sky+HD box. I have good wifi with a 98% signal strength but no IP address for the On Demand box diagnostics and no connection to network. It is showing two white lights on the front.
Any more ideas? Could my On Demand box have died?
15 Nov 2018 07:53 PM
Posted by a Superuser, not a Sky employee. Find out moreAre the power light and the yellow ethernet lights lit on your On Demand connector?
15 Nov 2018 10:11 PM
Do you mean at the back of the On Demand Box, where the Cat 5 cable plugs in? The front of the On Demand box displays two white lights. I will check tomorrow morning for the ethernet communication lights. I will also change to a different Cat 5 cable or if I can find one in my cable box, one of the superior shielded Cat 6 cables. I have checked that the Netgear Wifi extender is working properly (situated about 1 metre away from the On Demand box) and it is, including transmitting DHCP requests and allocation of LAN internal IP addresses, from the TP-Link Archer 400 VDSL/2 modem/dual band router, where the master DHCP server is located. I am connecting to a 2.4GHz wifi net not a 5GHz.
Wilson
24 Nov 2018 01:17 PM
Hi, I got Sky box 2TB HD, and BT Hub 6. Until a few days everything was fine. Now sky box doesent see any WiFi at all. There is no problem with my WiFi, 4 phones, 2 tablets, one laptop, xbox one, no problems on connecting. I separate the on BT Hub 6 the 2,4gh from 5gh. Still nothing. I dont know what to do anymore. Help.
@Jam3114 wrote:I got a message saying there was a problem and to go to sky help on demand. From the screen it should fail fail on broadband. I reset and now when I try to reconnect with was or WiFi password it can't locate a network. WiFi is working correctly. I didn't know there was an issue with the on demand section until in tried to download a box set.
I'm not sure what else to try.
25 Nov 2018 12:03 AM
Hi, my son disconnected the Ethernet cable from my router which connects to my sky box. It was only removed for a few minutes whilst he moved it. Plugged back in and now I’ve no on demand service it’s just saying fail to connect, no error code.
Tried unplugging everything and leaving for 5 min replugged back in and turned skybox and router on and still nothing.
Should it connect instantly using an Ethernet cable or does it take a while for it to find the internet?
