2
This discussion topic has been answered Discussion topic: Sky hd box stuck on standby
This message was authored by: Burnsie1
My sky hd box won't turn on, either manually or by the remote control. I've gone through every helpful tip I could find,to no avail. Any ideas as what I'm supposed to do.
This message was authored by: oj01 Answer
Re: Sky hd box stuck on standby
@Burnsie1 You own the box. Sky don't repair or replace them anymore. You can't independently replace them either as the viewing card can't be re-paired to a different box.
If the box is beyond repair, your only options (if you want to stay with Sky) are to switch to Sky Q or Sky Stream.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
