Discussion topic: Sky box not come on and remote control not working
This message was authored by: W12abl
Remote stopped working but red light is coming on switch off box but now won't come on ?
Avatar for W12abl
Level 0 icon
Re: Sky box not come on and remote control not working
I did not get an answer .
Did you expect an instant response 😞
This forum is primarily customer-to-customer help
Try forcing a software update (See my Sky Plus FAQ, link below in my forum signature)
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
@W12abl if the red LED in the end of the remote is lighting up when you press a button, the likelihood is that your remote is working ok.
What happens to the power light on the front panel of your Sky box, when you use the remote to turn it on? Does it change from red (or amber) to green? Or does nothing happen?
