Discussion topic: Sky box no signal
Message posted on 24 Oct 2025 10:27 AM
Sky box no signal
States no signal but weather ok , have switched on and off and reset a lot of times and box says initialising but doesn't progress from there
Message posted on 24 Oct 2025 10:39 AM
Re: Sky box no signal
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
- The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
- The Tuners in the sky box
- The input sockets on the Sky box
- The plugs on the cables
- The cables themselves
- The Sockets on the dishes LNB
- The dishes LNB has gone faulty for the connections the box is using
- You have plugged your Sky+ box into a dish that is only compatible with Sky Q
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Message posted on 24 Oct 2025 12:45 PM
it needs a sat signal to finish off initialising. had the same mid sept with sky+hd so tried/checked everything ( and didnt want to pay for a local independant engineer ) so in the end upgraded to sky q
hopefully you can get sorted
Message posted on 24 Oct 2025 01:05 PM
@peter+t20 wrote:it needs a sat signal to finish off initialising. had the same mid sept with sky+hd so tried/checked everything ( and didnt want to pay for a local independant engineer ) so in the end upgraded to sky q
@GG131 As Peter says your two options, to stay as a Sky customer, are to get a local engineer (at your own cost) to fix it or speak to Sky and switch to Sky Q (satellite) or Sky Stream/Glass (streaming).
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
