Discussion topic: Sky + box no signal
This message was authored by: smcam
Sky + box no signal
A couple of weeks ago my Sky + box stopped getting a signal.
Yes, there is work going on as there is scaffolding up but that has been up since the end of last year but only the last couple of weeks that this has happened.
The box is not getting a signal and will not initialise.  Any assistance without the use of an engineer will be grateful.
Re: Sky + box no signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Could the dish have been knocked by whoever's working on the scaffolding?
