Discussion topic: Sky+ box intermittently losing signal on random channels.
This message was authored by: AFOY
Hi I intermittently lose satellite signal on various different stations it's never the same but is becoming more regular. I have a sky+ box. Does anyone else get this?
Re: Sky+ box intermittently losing signal on random channels.
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out someone to check your system, another option is to move to Sky Q as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Is the box Sky+ or Sky+ HD..... it is getting old or even very old in the case of Sky+.
This message was authored by: IanP60
You are not alone with this problem. Nothing to do with dish, trees, leaves or the HD box getting old. I have had all this checked. It has to be a SKY issue with the transmissions. It is down to SKY to sort this issue out and sorry but this may take some time.
Nope. If it was a transmission issue ALL subcribers would be affected and clearly they're not.
