Discussion topic: Sky + box hard drive fault
This message was authored by: Ianastill
Sky plus won't record or pause
Re: Sky + box hard drive fault
You could try a full System Reset as a last resort, but failing that, I'm afraid the box has failed. Unfortunately it's no longer possible to use a replacement Sky+ box, so you would need to consider upgrading either to Sky Q or Sky Stream.
OR replacing the HDD which isn't easy on DRX890/DRX895 boxes😟
