2
This discussion topic has been answered Discussion topic: Sky+ No sound on HD channels
This message was authored by: dave+ross+57
My 40 inch tv seems to have died. To convince myself that the tv is faulty and not my sky+ box I have plugged the sky+ box into an older smaller tv using HDMI connection. This works fine apart from no sound on HD channels. I'm hoping this is an issue with the old tv  and nothing to do with my Sky+ box. I didn't have a sound problem on the 40 inch tv before it packed in. I intend to replace the 40 inch tv soon just want to be sure I don't have a sky +box problem
This message was authored by: Mark39 Answer
Re: Sky+ No sound on HD channels
Check that you don't have DolbyD turned on in your Sky box sounds settings.
Avatar for dave+ross+57
Matter resolved by Mark39, many thanks.
