The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
15 Feb 2019 01:29 PM
I’ve a 49 inch I can use code 2704 it now s turns tv on/off but don’t do volume
15 Feb 2019 06:53 PM
Thank you for code 2704. Worked for my TV aswell - to swich on/off but not for sound. Hope someone soon finds a code for volume to!!
24 Feb 2019 12:00 PM
Has anyone managed to find a Remote code for this Hitachi TV Model yet? Sky say they are adding codes all the time. This is last years model though, you would think there would be one available by now.
24 Feb 2019 12:08 PM
Posted by a Superuser, not a Sky employee. Find out moreMy post on 5 January explains how to find the code, if one exists for your TV.
24 Feb 2019 12:16 PM
Tried this several times, dosent work for Hitachi model number 50hb26t72u.
24 Feb 2019 01:38 PM
Posted by a Superuser, not a Sky employee. Find out moreAs explained earlier, this process tries every code on the database chip in your remote. If it doesn't find a code that works, there's no code for your TV.
14 Sep 2019 08:20 PM
Hi there for a rev9 remote it is 1177.
Not sure whether it works with a rev10 but mine worked for me.
Hope this helps
15 Sep 2019 02:07 PM
The CODE for both the HITACHI 32HB6T61U and 22HB11J06U is 1177 on either a v 8 or 9 remote, so worth a try.
02 Oct 2019 03:27 PM
Thanks for the tip it worked after 100 attempts
18 Jan 2020 11:27 PM
Why 100 attempts? Nothing is working for me 😩 x
27 Jan 2020 04:37 PM
Can you do the blink back proceedure and share the code with everyone please, you will make a lot of people happy 🙂
Identifying remote TV Remote Control Codes (Blink Back)
The following steps will allow this code to be identified.
1. Press the TV button on the Sky remote
2. Hold down Select and the Red buttons together for approximately two seconds, until the Red LED on the Sky remote blinks twice.
3. Key in 990 on the remote.
4. Key in 1 on the numeric keypad and count the number of times the Red LED blinks. The number of blinks will indicate the first digit of the code
(Note that a 0 is represented by no blinks where you press the key)
5. Input 2 on the numeric keypad and count the blinks to identify the second digit of the code.
6. Input 3 on the numeric keypad and count the blinks to identify the third digit of the code.
7. Write it down and keep it safely
Thank you this only takes about two minutes
22 Feb 2020 12:09 PM
Hi all
i did the blink test and got 1177 but still nothing ..... frustrated x
22 Feb 2020 01:25 PM
Posted by a Superuser, not a Sky employee. Find out more@0dy70 if you've been through the process I described earlier, without success, there's no code on your remote for your tv, I'm afraid.
The blink back process reveals which code is already programmed into the remote.
22 Feb 2020 02:44 PM
👍🏼😩 x
11 Oct 2020 01:33 PM
Hi have you tried 1221????? That seems to work on my Hitachi
