Sky +HD remote code for a Hitachi 43hb26t72u
Runner
Post 1 of 21
Hoping someone can help.
I can't find a working remote code for a Hitachi 43hb26t72u.
Box is a Sky+HD box remote is a rev10.
I've tried codes for Hitachi, Vessel and Finlux, with no joy.
Can anyone help?
Thanks in Advance
Oracle
Post 2 of 21
Re: Sky +HD remote code for a Hitachi 43hb26t72u
You don't say what codes you've tried. Have you tried the ones given by Sky's remote codefinder for your model tv? And the ones suggested when you leave out the TV model number?
Runner
Post 3 of 21
Hi,
 Thanks for replying.
Yes, I've tried all the suggestions for Hitachi, Finlux, and Vessel and no joy.
Also tried other codes from other sites.
Regards
Runner
Post 4 of 21
Hi there,
having same problem did you find a working code?
Runner
Post 5 of 21
Have a same problem. Tried to call SKY not any luck ever. My TV is Hitachi 50HB26T72U. Cant find a code nowhere. Tried loads of codes none of them working. Its so annoing. Could anyone help please?
Oracle
Post 6 of 21
If you've tried the codes listed by Sky's remote code finder to no avail, then no code has been previously found to work with your TV. You can check ALL the codes held by the remote to see if there's one that works  but it's a laborious process. If you want to try it:
1. Press Select and Red together for several seconds until the LED flashes twice.
2. Press TV then standby alternately (TV, then Standby, TV, then Standby etc) until your TV switches off. If/when it switches off, press Select to store that code.
If you find a code that works, post again and someone will explain the 'blink back' procedure so that you can establish which code worked.
Runner
Post 7 of 21
Re: Sky +HD remote code for a Hitachi 50hb26t72u
Hello, have the same hitatchi tv 50hb26t72u, sky advisor dosent recognise tv's model number, did you find a code? Really frustrating.
Runner
Post 8 of 21
Sorry - no luck so far... Hoping soon somebody crack the code and post it here
Oracle
Post 9 of 21
@Lindina if you've tried all the codes, as I described earlier, and none works, then there's no code for your tv in the database chip in your remote. Your remote isn't updated with new codes, I'm afraid. The alternative might be to invest in a one-for-all remote that can control both your TV and Sky box.
Runner
Post 10 of 21
Yes I tried but no luck. Remote control is sky hd rev.10. Dont think there is any newest controls? Its last on the list what sky shows when tried to programm remot control
Oracle
Post 11 of 21
Yep, you're right I'm afraid, Rev10 is the latest version.
New Viewer
Post 12 of 21
6C45E881-C534-41C4-9EE5-6B50E3C66BD0.pngIt states that the codes are updated?
Runner
Post 13 of 21
I'm havinghe same problem ,cant find a code for HB50 Hitachie.
seems like they only go up to a 32 inch screen anything bigger thanthat they dont have codes for.
Runner
Post 14 of 21
Phoned Hitachi customer services who pointed out that the code was in the instruction manual (which is pretty poor) with the code 1177. Tried this several times, Still no joy, I have a rev10 sky remote sky hd 2tb, not sure if this code is for skyQ?
Runner
Post 15 of 21
Hi just tried this code 1177 on my hitachi 50inch with rev9 remote and it now switches tv on and off using sky remote but no volume control arhhhh.
Recommended Threads
8 minutes ago 10:37 PM
Oracle 16 minutes ago 10:28 PM
21 minutes ago 10:23 PM
23 minutes ago 10:21 PM
Daffodils 29 minutes ago 10:15 PM
