11
This discussion topic has been answered Discussion topic: Sky HD box stuck on recording channel
This message was authored by: Simon+Krish
Guys had a sorfwear update by sky on the 4th Oct 2024.
since that event , had trouble with channels .
the old way, watch one channel record a differnt channel .
new way after sky sabotaged by box !!
watch one channel , can only record the actul channel am recording !!
also of a late night I used to record two show at the same time , NOT any more , clash and none get recorded .
its all part of getting me to upgrade to now the defunked "Sky Q" another merry go round starts .
This message was authored by: Annie+UK Answer
Re: Sky HD box stuck on recording channel
See my FAQ on how to access the Hidden menu, there is an option there that can turn of single feed mode
Does your box have 2 cables coming from the dish?
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
You did not have a software update for Sky Plus as Sky have dropped ALL software updates and the last one was years ago, maybe you had a slight power outage that would put your box on channel 998
@Simon+Krish no software update for years, as @Annie+UK posted. This is not the result of anything Sky has done.
Your 'symptoms' suggest you have a signal from the dish on only one cable. Check your signal strengths Service > Settings > Signal
The white part of all four bars should be at least half way across.
I don't know what you mean about Sky Q being defunct. It's still perfectly viable.
Avatar for Simon+Krish
Hi checked signal .
only TWO white bars .
input 1 signal quailty about 10% dark blue .
It's the white part that is important and that looks OK, but your box seems to be in single cable mode as there is no INPUT 2 listed
Hi Ann, thanks how do i get back the second channel mode ?
Yes two cables
Yes turned off single mode
Do you now have 4 bars showing Signal/Quality? If so they should all be much more than 50% and your box should now be working better and be able to record two live channels at the same time
That was it . Restore second out put.
back to normal .
it was a sky phone call that talk me into turning that into a single mode .
not sure why, well i do , ive been under a lot of SKY pressure to upgrade to skyQ, which i read on this forum is also being not offred to new customers , as Sky want to go into total "streming only" services .
Should be fine now, no need to move to another service YET 😈
