Discussion topic: Sky+HD box isn’t getting a satellite signal
This message was authored by: CCY
I am due to get Sky Q installed on 22nd August. The installation had been delayed dunno an Ethernet  able having to be installed. I am concerned that my Sky+HD has been switched off
Re: Sky+HD box isn’t getting a satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
@CCY your Sky+ box isn't switched off when you upgrade to Sky Q. The only possible connection between the no satellite signal message you're seeing, and the upgrade to Sky Q, would be that the LNB on the arm of your satellite dish has been changed for Sky Q. That would result in a no satellite signal error on your Sky+ box but I assume that you haven't had an engineer visit for the Sky Q installation.
That aside, the possible reasons for a no satellite signal error are as @Annie+UK posted. Just a coincidence.
