Discussion topic: Sky+HD Ethernet connection with BTsmart hub2
This message was authored by: Mrskinny7
Hi guys
Our Sky+HD system had been working perfectly for many years with box connected to the BT broadband router via cat 6 Ethernet cable.
Just recently we upgraded to the BT home hub2 on Halo 3+ and realised that the sky+ HD box was not connected to the router.
All other devices were working fine so tried resetting the router and the Sky+HD box without succes.
I also tried a factory reset on the router and swapping over with the Fire TV Ethernet cable which also goes back to the router.
I can get connection via wifi but want the  speed and reliability of the Ethernet.
I did get the Ethernet to connect once but I hadn't done anything, we turned the TV on one morning and it had connected to Ethernet but a few minutes later it disconnected and returned to wifi.
Any ideas guys?
Re: Sky+HD Ethernet connection with BTsmart hub2
Weird, we have a HH2 and Halo 3+ and our boxes connect with no issue, I do have their addresses set to static on the Sky boxes
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for Mrskinny7
Hi Annie
Thanks for your reply.
I didn't realise that IP address settings for Ethernet connection could be accessed and altered on the Sky+HD box; could you please advise further?
On the Sky box network setting you can choose MANUAL for the IP address, you enter thr routers adddres: 192.168.1.254 the mask: 255.255.255.0 then the boxes IP you want to use (I use 192.169.1.200 for mine)
Thanks Annie
The only option on my Sky+HD box within the network settings is "manual wireless configuration".
Annie
I've just re read your last post and realise what you are suggesting so please disregard my last post as I couldn't see how to edit it.
Hi Annie
I'm familier with accessing the Smart hub manager but I'm affraid my knowledge and experience of changing settings is zero.
Could someone offer some kind of a walk through to change the IP setting as suggested earlier?
I have tried to access the BT community forum but the BT "Confirm verification" email won't aknowledge me clicking on the GUI verification button......who'd of thought it would be so tricky😁
