Discussion topic: Sky HD Box isn't getting satellite signal
Message posted on 29 Nov 2024 05:14 PM
Hi there, our Sky TV appears not to be working at present. The message as is the title is what appears on screen.
We have turned the box on and off several times to no avail.
Is there any help which you can assist us with
Mark
Message posted on 29 Nov 2024 05:20 PM
Re: Sky HD Box isn't getting satellite signal
Almost certainly a dish misalignment. Although Sky themselves no longer support Sky+ and Sky+HD, if you have Sky Protect through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense to check it (or upgrade to Sky Q or change to Glass / Stream).
Message posted on 29 Nov 2024 05:22 PM
Unfortunately Sky no longer provide engineer support for Sky+ boxes unless you have Sky Protect. You'll need to engage a local satellite installer to take a look for you.
Alternatively now might be themtime to upgrade to Sky Q. Any dish issues will be put right at no additional cost to you, as part of the Sky Q installation.
Message posted on 17 Dec 2024 02:31 PM
No my HD box isn't getting a satellite signal what happens next??
Message posted on 17 Dec 2024 02:41 PM
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 17 Dec 2024 02:48 PM
I will need someone to come out?
Message posted on 17 Dec 2024 02:50 PM
As per the reply above your post…
