10
This discussion topic has been answered Discussion topic: Sky+HD Box doesn't have aerial port. Is it possible to use a satellite to aerial adapter and use it?
This message was authored by: Jim10001
Sky+HD Box doesn't have aerial port. Is it possible to use a satellite to aerial adapter and use it? I am wondering since I have no sattelite connecters in my room. Can I just use an adapter and connect a aerial from there? Will it function just like it would with a satellite?
Thank you!
This message was authored by: Mark39 Answer
Re: Sky+HD Box doesn't have aerial port. Is it possible to use a satellite to aerial adapter and use
@Jim10001 wrote:
Sorry, I should have mentioned earlier that I do not have a aerial port. That's why I was wondering if I use a converter.
I'm guessing you have a SkyHD receiver with no '+' functionality.
If you have a tv in your room, you would connect the indoor aerial to your tv, not your Sky box.
No. Digital television and satellite tv are broadcast on completely different frequencies.
Avatar for Jim10001
Oh, that's a shame. Is there any other way to access live TV without a satellite cable?
You could try an indoor tv aerial, but really they're only any good if you're fairly close to the transmitter and in an area with a good signal.
Avatar for Jim10001
All Sky+ HD boxes have an aerial port🤔
Avatar for Jim10001
Thank you. It's might what I have to do. The sky box was in the living room which did have a satellite connection. Since getting replacing the sky box I was wondering If i could set it up in my room. So thats probally the answer. Thank yo very much for your help though.
Do you have an active Sky TV subscription?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Jim10001
No. But I am pretty sure that simple satellite/aerial would still work fine? Please correct me if I am wrong.
@Jim10001
While devices labelled as a 'satellite to aerial adapter' do exist , they are essentially pointless.  These are fundamentally different broadcast technologies, and it's not possible to receive digital terrestrial television broadcasting through a satellite dish, or satellite television through an aerial.
The small silver components are cable connection adapters (screw thread to push fit or vice-versa), not signal converters.
