Discussion topic: Sky+ HD Box Suddenly lost sound/audio
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky+ HD Box Suddenly lost sound/audio
@pamscam wrote:
So will this be a permanent thing?  Surely not!
Shouldn't be. Once the handshake has completed ok, it should remain ok.
This message was authored by pamscam This message was authored by: pamscam
Thanks.  Odd though.  It's a new Samsung    and only been in use for 3 days but has not happened before.
Oh dear,  turned new Samsung tv on this morning and again no sound on SKY. Not a SKY problem as that is ok in another room.  Turned power to tv off and then on and sounds works till the next time.  What next
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Posted by a Sky employee
Update - Spoken to customer and after a few checks we found the issue to be with Samsung, the customer is going to contact them directly for support. Thanks 🙂
Lisa - Sky Tech Team Expert
This message was authored by George+Tidy This message was authored by: George+Tidy
Had the same problem took the advice to turn off TV and edit a few minutes and hey presto sound. Thanks very much for the help
Yes it does work and maybe for a day or two.  Ours has been ok for 2 or 3 days and this morning - no sound!  Turned off waited a while and turned on again.  This
is not right but not sure what to do.   Seems a common problem so a new set might not solve the problem.
This message was authored by DaveW62 This message was authored by: DaveW62
My Sky + ws in the middle of playing something yesterday when the sound suddenly stopped. I tried restting the box, then I tried a software update, both to no avail. Despite the fact the TV was working fine, thanks to the answers here I unplugged the (Sony) TV for a few minutes and when I restarted it the sound was back 🙂
This message was authored by alun+f This message was authored by: alun+f
Hi;
Yes the same old Sky+ HDMI handshake problem. A number of people have had this problem on many different set manufactures. The common link is the Sky + HDMI. I have cleared this problem must be 3 to 4 times now, by powering off for 5minutes both the set and Sky+ box .on powering them up gain fault "fix  until next time".
This message was authored by TH2018 This message was authored by: TH2018
As far as I can see (and I'm definitely no expert) this happens - to me anyway - only with downloaded content. It usually starts with the ad break being mute, then sometimes when it gets back to the show the sound is back on, sometimes not. I've found that if you wait and come back to it it will come on. I feel it may be due to slower than usual download of the programme. Video is downloaded but if you watch it as soon as it says "available", it's like the audio has to catch up. So when you get to the point where, to continue the theory, the audio has not yet downloaded, it's not there so you can't hear it. Almost every time it's happened to me I have done nothing but pause it and go back maybe 10 mins or so later and it works fine. Just now it worked when I simply ran the progamme back a few seconds. Don't know if it always will.
But that's my guess: it's to do with somehow the audio not being downloaded to your box at the same speed as the video. Makes sense when you think about it. I had a similar problem with a programme being "available" but if I scooted through ads it suddenly said "end of programme." The video and audio at that stage, ie the whole file, had not yet downloaded fully and so I had to wait for it to do so. FYI i have fast broadband (360 Mbps with Virgin) so it's not my broadband connection being slow.
Dunno if that helps, but it is another thing to try. The other option (boring as it is) is to watch your download till the percentage is above 50% and then start watching it. Usually by the time you get to the end of the programme the download has caught up.
This message was authored by PatrickPK This message was authored by: PatrickPK
Had the same problem here today - after much messing around, it was the HDMI slot on the TV that seemed to be the cause - switched the cable to HDMI2, everything fine. LG TV.
This message was authored by bakerdave113 This message was authored by: bakerdave113
Suddenly happened today to my old, somewhat glitchy SkyHD box and 2 year old Samsung QLED set. Switched cables, ports even tried an old HD box! After reading this thread I tried switching off TV for 5 min s. Whoopee sound back ! What I think is that I've recently taken to switching everything off at the mains rather than leaving in standby. That must have caused the issue ( I hope)
This message was authored by Nigeinnotts This message was authored by: Nigeinnotts
Happened to me today.  I Player, netflix etc all had sound.  So I tried the DVD player and DVD recorder, no sound there either.  Unplugged TV, plugged back in, everything fine.  Seems to be a smart TV problem maybe ?
On average, new discussions are replied to by our users within 100 minutes
