09 Aug 2021 08:48 PM
Hi there does anyone know if an old sky + box can be used as a freeview box. My folks have bought a holiday home which has previously had sky so has a dish and cabling. They dont have an ariel so wondered if they can connect their old sky + box to access Freeview through it without having a sky subscription for that address.
09 Aug 2021 08:50 PM
Posted by a Superuser, not a Sky employee. Find out more@Nodrog87 No sky boxes can be used as a freeview box as they are two different systems. It can be used as a Freesat box using an existing Satellite dish.
Freeview needs an aerial.
09 Aug 2021 08:51 PM
Posted by a Superuser, not a Sky employee. Find out moreNot Freeview - that's delivered via a TV aerial, but they can receive the free to air Freesat channels using a Sky+ box. No recording, of course, without a subscription.
09 Aug 2021 08:52 PM
Thank you very much for getting back to me. Thats great thanks. Do you know what I'd need to use it as a Free Sat box.
09 Aug 2021 08:53 PM
Posted by a Superuser, not a Sky employee. Find out more@Nodrog87 Nothing other than the cables from the dish being plugged into the back of your Sky + box and connected to a TV by HDMI
09 Aug 2021 08:55 PM
Posted by a Superuser, not a Sky employee. Find out more@Nodrog87 just a note of caution - if the previous owners had Sky Q, a Sky+ box may not work, as the LNB (on the arm of the dish) is changed for Sky Q.
09 Aug 2021 08:56 PM
Thank you.
09 Aug 2021 08:59 PM
Would it require a viewing card
09 Aug 2021 09:01 PM
Posted by a Superuser, not a Sky employee. Find out more@Nodrog87 Only for the likes of Channel 4HD & Channel 5HD I believe, if they are not fussed with HD, then all the normal SD channels such as BBC,1, 2, 4, ITV, Ch4, Ch5 and few other channels are freely receivable without one
09 Aug 2021 09:02 PM
Freeview requires an aerial and not a dish, a sky box can be used to pickup FreeSAT without the need of a viewing card
21 Jan 2022 12:30 PM
In the past I've bought a Sky Freesat card for approximately £25 which gives you free sat and some additional channels. Works the same way as a subscription card, has to be linked to the box you install it in.
21 Jan 2022 04:34 PM
AFAIK this service has been phased out
13 Sep 2022 07:09 PM
What should I do if the previous owners did have a sky q box and I want to view freesat on the sky+ box? Thanks in advance
13 Sep 2022 07:14 PM
You would need to have either the LNB on the dish downgraded or changed for a Hybrid LNB
13 Sep 2022 09:18 PM
Thanks you for your reply.
The situation is like this,
My household had sky q with multiroom. The multiroom has been cancelled due to finances but I want to watch free view or free sat in the multiroom using a sky+ box. (The multiroom sky q box has been returned to sky). The main sky q box is sill active in the living room. What do I need to do to make that work or is there a better work around?
On average, new discussions are replied to by our users within 100 minutes
