Discussion topic: Sky Comedy disappears at 8pm
This message was authored by: SG20
Does anyone have any idea why the Sky Comedy channel 114 gets an error message about no satelite signal every day from 8pm? It is fine to watch throughout the day and then bam! 8pm it dissappears. Really annoying as I like to watch Will and Grace and can't cause the channel shuts down. Any help would be much appreciated x
Re: Sky Comedy disappears at 8pm
Most likely you have a marginal signal which drops just enough to be inadequate during the evening (unless this happens at precisely the same time each evening when there might be an interference issue). You could try checking the signal strength (Services > Settings > Signal) during the daytime after tuning to the channel. The white part of all 4 bars should be at least half way across.
