Discussion topic: Single channel loss of signal.
This message was authored by: User_Al
Has Sky switched off BBC 1 ? Last couple of days we've had loss of satellite signal but only on this channel.
Re: Single channel loss of signal.
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
No. It's quite possible to have a loss of satellite signal on only a few or even 1 channel. If it's still the same after you've restarted your Sky box, most likely your dish is slightly out of alignment. Unfortunately Sky don't support Sky+ equipment any more (unless you have Sky Protect) so you would need to get a local satellite installer to come out and check it for you.
Or you could upgrade to Sky Q, when any dish problems will be addressed as part of the installation.
Avatar for User_Al
All vitals are good - it's just BBC 1 showing loss of satellite signal.
@User_Al  Sky can't switch off any channels that are not their own, BBC channels are not owned by Sky, nor is they satellite the broadcast from.
Which BBC One region are you in? There will be other channels on the same frequency that you can check to see if they're affected too. As others have said Sky can't just switch off BBC One and it's almost certainly a dish alignment fault.
Avatar for User_Al
@xenon81
The dish is fine - it's just BBC 1 - all regions.
@User_Al wrote:
@xenon81
That suggests otherwise, if the dish is fine then you'd be receiving ALL channels
@User_Al wrote:
@xenon81
How did you check it?
Avatar for User_Al
Standard alignment for Astral 2, northeast Scotland - all channels no problem except for bbc 1.
@User_Al  How did you check the dish alignment?  A visual check won't reveal anything.
Incidentally are you using a communal setup or your own private dish?
@User_Al
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Assuming BBC One Scotland is your region, how is your signal on BBC News, BBC Alba, and BBC Radio 1, 2, 3, 4 and 5?
