Discussion topic: Says a problem with my hard drive unable to use pause or record
This message was authored by: Annmarie881
Message posted on 21 Sep 2023 02:18 PM
Hi can't use pause or see recordings and other services that I have
Find out more
Message posted on 21 Sep 2023 02:22 PM
Re: Says a problem with my hard drive unable to use pause or record
I'm afraid it sounds as though your Sky box is on its last legs. You could try a Planner Rebuild, and a Full System Reset (which will erase your recordings) to see if it temporarily restores normal working. But ultimately you'll need either to replace the box with a used one from the likes of ebay, or upgrade to Sky Q.
