Discussion topic: Satellite no signal
This message was authored by: Rita27
Satellite no signal
No channels on tv
Re: Satellite no signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Rita27
So are you seeing a "no satellite signal " message?
@Rita27
What are your signal strengths like, this could be found via services on your remote then settings > signal. The white vars on input one and two need to be at least half way along.
