Discussion topic: SKY+ Network settings for CAT5 / Ethernet connection to BT Hub
This message was authored by: Phantomtwin
Just taken delivery of a new BT hub (after the previos one failed after 10 years) and while everything is connected as before the SKY + box shows 'FAILED" messages when you look at the Network settings for connection to broadband etc.
Such a long time since I did the previous set up - should this be automatic or do I need to manually enter IP settings for the SKY+ box?
Hoping that makes sense - any help welcomed!
Re: SKY+ Network settings for CAT5 / Ethernet connection to BT Hub
I setup manual IP addresses for our Sky boxes on our BT Smart Hub 2
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Phantomtwin
any simple suggestions / walk thru ref what this involves would be welcomed? Set up in the BT hub as opposed to the SKY Box?
You need to set the IP on the Sky box
IP example: 192.168.1.250 (bold number can be between 1 and 253 but not match an existing device on the LAN)
Mask: 255.255.255.0
Gateway (routers address) 192.168.1.254
DNS: 1.1.1.1 and/or 1.0.0.1 (cant remember if the Sky+ takes 1 or 2 DNS addresses)
