Discussion topic: SKY HD+Box and full fibre broadband
This message was authored by: Rae4
We have kept our sky+HD box as we use it via digi senders to transmit to others rooms. We are moving to full fibre broadband, will it still work?
Re: SKY HD+Box and full fibre broadband
Your broadband has nothing to do with the digi sender
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for Rae4
Thanks Anne. Sorry was not clear. Said about the digisenders to explain why wanted to keep the HD+ Box.
Really my query is will the HD+BOX work with full fibre broadband?
It should do as Wifi and Ethernet are usually backward compatible, you'll need to setup wifi again if that is how you connect to your Sky box
