Discussion topic: Recordings on my SKY HD+ fails to playback.
This message was authored by: AL54
 Hi any help appreciated,  replaced an old HD+ box last October with a refurbished one bought on Ebay now experiencing problem with playback.  The recordings show as available on the Sky planner but fail to play , only see a blue screen and reverts back to the tv chanel. It also occurs when trying to download from Catch up TV. Personally,  i think the hard disk has failed?
Re: Recordings on my SKY HD+ fails to playback.
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
You may be right. Try rebuilding your Planner, as described here: https://www.sky.com/help/home/sky-tv/sky-tv-plus/sky-plus-watching-sky-tv/sky-plus-recordings/articl...
Avatar for AL54
Already tried a rebuild planner
It would have been helpful to say so. Did it complete? What else have you tried?
Avatar for AL54
Mark39  I started with a re boot and checked skycard,  then tried  to rebuild planner and  finally a system reset,. nothing seemed to make a difference , think iv'e run out of options !
What model was the old one.... what model is the refurb?
Avatar for AL54
Both boxes were  DRX890W  the newer slime line  model
Changing the HDD is tricky but can be done... buying a replacement box is easier and not much more expensive, especially when you must make sure you get a media rated HDD🤔
