Discussion topic: Re: When I go into my planner it saying system fault
Message posted on 29 Jun 2023 12:35 PM
Can I speak to an advisor
Message posted on 29 Jun 2023 12:37 PM
Yes, if you call, as this is a customer helps customer forum.
Message posted on 29 Jun 2023 12:42 PM - last edited: 29 Jun 2023 12:45 PM
You need to try a planner re-build.
edit: @Annie+UK may have the process to follow.
Message posted on 29 Jun 2023 12:51 PM
Planner rebuild:
• Go to Help
• Select Sky+ Rebuild
• Press SELECT (this will start the rebuild)
If the above does not work try the following (Note: the first 5 steps are better done whilst looking at the remote control as the feedback on screen can be confusing):
• Press 0 (very old boxes may need you to press 4 instead)
• Press 0
• Press 1
• Press SELECT (You should now be in the hidden menu)
• Press 7 (Sky+ Rebuild)
• Press SELECT (An on-screen message will be displayed)
Message posted on 29 Jun 2023 01:29 PM
@Lladder try the Planner Rebuild first, although a System Fault is likely to mean the hard disk has failed. If that's the case, the box will need to be replaced.
