Discussion topic: Pairing existing subscription card with new digi box
This message was authored by: Gina04
We have received a new sky box, but cannot pair the remote to the new box.
we purchased it from a independent retailer and need the viewing card paired.
but we cannot get onto the screen where it gives us the information to do so as the remote doesn't work sync to the tv??
Re: Pairing existing subscription card with new digi box
Is it a Sky+ box you have ?
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
@Gina04 ypu don't need to be on any particular screen to link your Sky+ remote with your TV. You don't even need your Sky box or tv turned on.
Follow the instructions here: https://www.sky.com/help/program-your-remote
Avatar for Gina04
Followed all of this and it doesn't work still repeated it a number of times, would it be to do with the version of remote we have? It's a old model
Avatar for Gina04
@caesarome Yes we have a sky+ box but a version 8 remote is this what the issue could be?
You can link any remote from Rev4 onwards. What happens when you try to programme the remote? Does the red LED in the remote end flash? Did you find your TV model in the list provided by Sky?
@Gina04  A Sky+HD box doesn't need you to pair a remote to the box, you should be able to use your original Sky remote if you didn't get one with the box.
https://www.sky.com/help/articles/sky-viewing-card-help-activate-plus
Which model of DRX890 is it or is it a DRX895?
