3
This discussion topic has been answered Discussion topic: Pace Sky + HD ver 9F3003 licks up when I try to use REWIND??
This message was authored by: bmitie
Had this box from the outset and it has been flawless until now and what the problem is if I pause, and then rewind the box will lock up and have to go through power off etc.
I have a spare but PACE has great pic quality and maybe there is a fix that might eke out a few more years.
I dont want sky Q ever.
This message was authored by: Annie+UK Answer
Re: Pace Sky + HD ver 9F3003 licks up when I try to use REWIND??
A rebuild might help if not a FSR can be done as a last resort
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Find a secondhand DRX895 or DRX890 these have the newest software that the pace box does not have
The pace HD box was, IIRC, recalled many years ago, so I'm surprised it has lasted as long as it did 🙂
Avatar for bmitie
Level 4 icon
I have a spare DRX 890 but as this PACE has been so good, I know about all the problems, I never used pause reqind very much and that may have helped.
By the way it could be my won fault ie pressing remote too many times.  I  may do a re build.
