Discussion topic: On screen message saying no satellite signal
This message was authored by: Lorraine41
Re: On screen message saying no satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
