Discussion topic: Not receiving satelite signal
This message was authored by furrough This message was authored by: furrough
screen reads
@Your Sky + HD box is not getting a satelite signal@@
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Not receiving satelite signal
Box/Cables/Dish issue
First reboot your sky box
If no better then check the cables are screwed into the box (hand tight) and check they are still attached to the LNB on the dish
Annie  ( Please Note: I am Neurodivergent )
Sky support for Sky+HD and earlier systems has ended, you can still get support if you already have Sky Protect insurance otherwise you'll have to find your own 3rd party company to get support from at your own expense
On average, new discussions are replied to by our users within 100 minutes
