Discussion topic: No sky signal and box says still initialising please return in a short time
Message posted on 16 Dec 2024 04:47 PM
This has been saying this since last weekend
Message posted on 16 Dec 2024 04:59 PM
Re: No sky signal and box says still initialising please return in a short time
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 16 Dec 2024 05:00 PM
Your Sky box isn't getting a signal from your satellite dish. Try turning it off, and checking that the 2 dish,connections are still secure. Turnmin again,after 4 minutes. If you're still seeing the same ,message, you'll need the dish and,cables to be checked. Unfortunately Sky no longer provide engineer support for Sky+ boxes unless you have Sky Protect, so you would need to engage a local satellite engineer to take a look.
Alternatively now might be the time to consider upgrading to Sky Q.
Message posted on 16 Dec 2024 09:13 PM
Which was when the storm passed over, so very suggestive of wind causing dish misalignment.
