Discussion topic: No sky satellite signal
This message was authored by: JB050946
Message posted on 15 Nov 2025 10:09 AM
Find out more
Message posted on 15 Nov 2025 10:16 AM
Re: No sky satellite signal
@JB050946 the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
