This discussion topic has been answered Discussion topic: No signal on tv
Message posted on 29 Nov 2023 06:02 PM
Hi TV is not working - no signal
Message posted on 29 Nov 2023 06:03 PM
@Abhha
”No signal” tends to be a message from your TV (in which case check the cables going to the TV).
@Abhha
Message posted on 29 Nov 2023 06:17 PM
Re: No signal on tv
Done all that. Can u send a signal boost?
Message posted on 29 Nov 2023 07:42 PM
Re: No signal on tv
Even if it were possible (it's not) it wouldn't help. No signal means your TV isn't getting a signal from your Sky box, so either the cable is faulty, your TV is faulty or your Sky box is faulty.
If your TV has more than one HDMI socket, try plugging the cable from your Sky box into a different one.
Message posted on 29 Nov 2023 08:11 PM
Re: No signal on tv
Message posted on 03 Jan 2024 01:52 PM
Re: No signal on tv
Due to the rain and strong winds my Sky is displaying no signal
Message posted on 03 Jan 2024 02:02 PM
Re: No signal on tv
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Message posted on 03 Jan 2024 02:04 PM
Re: No signal on tv
I'm assuming that's no satellite signal. Poor weather can certainly affect satellite reception, particularly if your dish is slightly misaligned or the LNB on the arm where the cables connect is ageing (they can start to deteriorate after 5 years or so). If it doesn't recover when the weather improves, you may need to get someone out to take a look.
Message posted on 28 Mar 2024 07:31 PM
Re: No signal on tv
I have checked all cables .
Still no signal
Message posted on 28 Mar 2024 07:40 PM
Re: No signal on tv
If you have a Sky+ box (where you have posted) then as Sky doesn't support these anymore you will need to contact a local company to you to come out and fix this for you.
Message posted on 28 Mar 2024 07:42 PM
Re: No signal on tv
As you've posted on the Sky+ board I presume you have Sky+ so you may need to arrange a local satellite engineer at your own expense unless you have Sky Protect through Domestic and General Insurance.
