Discussion topic: No signal on some channels oncluding 101 BBC HD
This message was authored by: BarryC73
Hi. No satellite signal message on some channels once BBC 1  channel  101, Comedy Central 112, BBC Alba 117,ITV2 118. No issues before today. All normal guidance followed.  No change
Any thoughts
Thank u
Re: No signal on some channels oncluding 101 BBC HD
Sky no longer supports Sky+ systems so you will have to engage a company local to you to come out and look at this for you as it might be that the dish has moved ever so slightly as doing so can cause issues like this.
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
