Discussion topic: No signal on some channels . Now nohome screen frozen
Message posted on 12 Jun 2025 08:15 PM
I have had issue an ongoing issue with losing signal on certain channel with weather changes. This happened again this week despite sunshine. Decided to unplug Sky HD plus box overnight. Switched on again today. Once loaded up - normal message that system initialising appears. This doesn't change at all and also added no signal issue on top. Have tried all of reset reboot methods and none work..And ideas?
Message posted on 12 Jun 2025 08:20 PM
Re: No signal on some channels . Now nohome screen frozen
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Message posted on 12 Jun 2025 08:49 PM
@BarryC73 Your Sky box can't initialise without a signal from the dish which really just confirms the 'no satellite signal' message.
Message posted on 12 Jun 2025 08:55 PM
Thank you. So I assume from that if dish realigned and signal fixed. Initialising would happen?
Can I also assume, that dish has went completely with no signal on some channels to no signal on any channels.
Message posted on 13 Jun 2025 11:49 AM
Hi. Is there a direct number to call Sky re Sky Q and free installation. Thanks
Message posted on 13 Jun 2025 12:21 PM
@BarryC73
No direct number unless you have a letter or email from Sky offering such an upgrade.
To call Sky dial 150 (free) from either a Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
