Discussion topic: No signal on skybox
This message was authored by: Paris855652-
No signal on skybox
We cannot get a signal!  Only receiving bbc2 and Netflix and catchup
Avatar for Paris855652-
Level 0 icon
Re: No signal on skybox
How do I get help with no signal on skybox
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
You can't get Netflix on a Sky+HD Box. So, do you have Sky Q?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
