This discussion topic has been answered Discussion topic: No signal on sky box
Message posted on 13 Aug 2024 02:53 PM
Hi,
I have no signal going into my Sky + box and in the settings page, under 'signal' it says not locked for the input 1 lock indicator and the same for input 2. I've tried all the guides online to try and troubleshoot but nothing works.
Message posted on 13 Aug 2024 03:19 PM
@shirely1958 wrote:
Thanks so much, does anyone know if there's something that can be done to fix this issue?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 13 Aug 2024 03:06 PM
Re: No signal on sky box
Hi @shirely1958 Just checking that you have a Sky Q box (this community) or an old Sky+ box?
Message posted on 13 Aug 2024 03:07 PM
Hi,
it's an old Sky + box but I rang Sky and they sent me a text link to post my issue in this forum.
Message posted on 13 Aug 2024 03:11 PM
Your thread has been moved to the appropriate Sky+ board.
Message posted on 13 Aug 2024 03:17 PM
