Discussion topic: No signal in summerhouse - since switching to Fibre?
Message posted on 20 Jul 2023 06:11 PM
Hi
I used to be able to watch TV in my summerhouse and now it says I have no satellite signal. I'm not sure when this started but I changed to Fibre broadband recently and wonder if this affects it?
I have Sky Q in the house with Fibre broadband. There is an ethernet connection to the garden which then connects to a Sky WiFi mini router/booster?
It's an old Sky HD box. It's connected to the sky dish through 1 input cable.
Other than that I have no idea of how it was setup or needs to be 😂 so apologies for the vagueness but wondering if anyone can advice what I need to do to watch TV again in the garden?
Thank you!
Message posted on 20 Jul 2023 06:26 PM - last edited: 20 Jul 2023 06:29 PM
Re: No signal in summerhouse - since switching to Fibre?
@cw67 wrote:
Hi
Thank you!
Hi @cw67
If the box in your summerhouse is an old SKY HD box then the satellite connection would not be affected by the change to Fibre (unless the installers did something with the Satellite cable to your Summerhouse)
Could the connection to the dish or even the cable have been affected by the recent heavy storms ?
Message posted on 20 Jul 2023 07:08 PM
There's nothing obviously visible but I suppose it could be the storms.
I've not tried to use it since probably last summer so hard to nail it down, just thought the only change in that time would be the fibre.
Do you think it will need an engineer visit to fix?
Message posted on 20 Jul 2023 07:15 PM
Difficult to tell but probably.
As the problem is with a SKY HD an engineer's visit is likely to be chargeable.
I have mobed the discssion to the SKY HD group in case those with SKY HD boxes can suggest something
Message posted on 20 Jul 2023 07:18 PM - last edited: 20 Jul 2023 07:22 PM
hi again @cw67
As you say you have SKY Q in the house & you now mentioned you haven;t checked the box in the summerhouse for a while -
Can I just double check that the SKY HD box has worked since getting SKy Q - SKY Q uses a different LNB so if you have not checked the box since the switch to Q - this is likely to be the reason (although there is a dual LNB called a Hybrid that has both types of connections)
Message posted on 20 Jul 2023 07:32 PM
Hi @nigea99
Appreciate the responses.
I'm certain it's worked since I got the Sky Q in.
My Sky Q subscription ran out and I had no Sky for a while then I took the very basic £5 a month package in the house so I could still keep the basic channels with record etc.
Not sure if I've used the garden TV since that change if that could affect it?
Message posted on 20 Jul 2023 07:40 PM - last edited: 20 Jul 2023 07:42 PM
@cw67 wrote:
Hi @nigea99
As I mentioned SKy Q and SKY HD do use different signals so you would have need this special 'Hybrid' LNB installing when you switched - SKY do tend to only install when there is a Freesat box and not very often just to SKY HD boxes.
When you switched to Q the Account would have switched so your SKY HD box would have become a view only box and no longer reliant on a subscription (the subscription was needed for Record / play functionality & of course the non Freesat channels)
So if it was working when you changed to Q then the time after without a subscription or later with a basic Freesat only (+ record) sub for Q would not affect the HD box capability to view channels
edit : How easy is it to tell whether all cables are connected to the LNB ? ( 2 for SKY Q & 1 for your HD box)
Message posted on 20 Jul 2023 09:02 PM
Apologies if this is a silly question but what exactly is an LNB and how would I check?
Message posted on 20 Jul 2023 09:24 PM - last edited: 20 Jul 2023 09:26 PM
Not silly at all - sorry we sometimes forget most people have no idea what an LNB is
a LNB is the electronic bit on the dish that collects the signals and converts them to the frequencies used by the receiver (LNB stands for Low Noise Block)
Please see an image in this link:Hybrid LNB
BTW the image shows it with the Rain cover slid up - this is usually down covering the connections
Message posted on 28 Jul 2023 01:21 PM
Hi @nigea99
Sorry for the slow reply. From what I can see there are 2 cables coming from the LNB.
Does this help at all?
