Discussion topic: No satellite signal
This message was authored by: Baldy4
Message posted on 12 Dec 2025 06:23 PM
No satellite signal
No satellite signal no tv
Find out more
Message posted on 12 Dec 2025 06:42 PM
Re: No satellite signal
@Baldy4 the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
