Discussion topic: No satellite signal
This message was authored by: Shangarasingh
No satellite signal
Our tv shows that your sky +HD box isn't getting a satellite signal . Your recordings in the planner and the on demand service may still be available. And it being 2weeks
Re: No satellite signal
Sky no longer support the Sky+ service. If you have Sky Protect insurance then you may still be able to get an engineer to attend and check your dish, but otherwise you'll need to contact and pay for an independent satellite installer to check your dish and cabling.
Your only other alternative is to switch to Sky Q and get a new box installed. Your dish would have the LNB changed by Sky too and all the cabling checked.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
