Discussion topic: No satellite signal
This message was authored by: sunbird21
No satellite signal
my sky sky +hd box is not receiving a satellite signal. I switched it off to see if rebooting it would help and now can't get any of my recordings either
Re: No satellite signal
@sunbird21  Is it snowing in your area or do you have snow on the dish?
@sunbird21
Your signal is likely to be affected if snow lands on the dish, in particular the LNB but should return to normal as soon as the conditions improve. Don't necessarily try to brush it off as accidentally moving the LNB will then necessitate an engineer visit to realign it. As a Sky+ customer that would be at your own expense.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
