Discussion topic: No satellite signal
Message posted on 22 Dec 2024 04:27 PM
No satellite signal
No satellite signal it says
I can't get all channels
Message posted on 22 Dec 2024 04:32 PM
Re: No satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 22 Dec 2024 04:35 PM
I am able to receive sky channels but no bbc itv etc
Message posted on 22 Dec 2024 04:37 PM
Message posted on 22 Dec 2024 04:37 PM - last edited: 22 Dec 2024 04:38 PM
@DPL
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 22 Dec 2024 04:38 PM
So what is best to do to get it fixed
Message posted on 22 Dec 2024 04:39 PM
@DPL Do you have a Sky+ SD or Sky+ HD box?
Message posted on 22 Dec 2024 04:40 PM
Contact an independent satellite engineer which will be at your expense so get a quote first.
Message posted on 22 Dec 2024 07:18 PM
Sky + hd
