Discussion topic: No satellite signal
Message posted on 02 Dec 2024 09:52 AM
No satellite signal
no satellite signal
Message posted on 02 Dec 2024 10:03 AM
Re: No satellite signal
Can you confirm if you have a Sky+ box or a Sky Q one ?
Message posted on 02 Dec 2024 10:15 AM
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
