1
This discussion topic has been answered Discussion topic: No satellite signal
This message was authored by: Fionametty
No satellite signal
My sky is not working. This has been an issue on and off for the last 2 weeks. Today the signal has gone completely and I cannot see any channels.
A message saying 'no satellite signal' is coming up.
We tried rebooting but nothing is working. Can you help me resolve the problem?
This message was authored by: Annie+UK Answer
Re: No satellite signal
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
