Discussion topic: No satellite signal
This message was authored by: Nicky8
No satellite signal
No satellite sign.. I've turned it off and on since 7am this morning.. please help
Re: No satellite signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
