Discussion topic: No satellite signal sky+
This message was authored by: Sandra19661
Iv had a message saying your sky HD+ box isn't getting a satellite signal. Your recordings in the planner may be available, however they are not. If I go onto planner it says your box is still initialusicone back in a few moments. , but nothing ever happens. Iv made sure all wires are plugged in , Iv tried turning it off and on again, along with the tv set itself, still nothing
Re: No satellite signal sky+
Recordings become unavailable, when you turn off your Sky box at the plug while it has no satellite signal.
The cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
Avatar for Sandra19661
Thank you, I was aware my box was outdated, I now have an appointment for sky q to be installed
@Sandra19661
I will cc in one of the other Superusers who has compiled a very helpful guide for those thinking of transitioning from Plus to Q which may provide some insight into something you hadn't considered.
cc
@nigea99
hi @Sandra19661
As @Daniel0210 mentions, you may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
