Discussion topic: No satellite signal on my Sky + Box
This message was authored by: Simon70
I have recently cancelled my Sky Q subscription and wanted to use my old Sky + box as a freeview box however it comes up saying Your SKY+ box isnt getting a  satellite signal.
I have tried rebooting, its all cables up as it should be.
Any ideas ?
Re: No satellite signal on my Sky + Box
The default LNB on the dish for Sky Q is NOT compatible with Sky+
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
@Simon70  The LNB on the dish will have been changed to a Q  (Wideband) LNB which Sky + boxes cannot use.  You can however replace this for a hybrid or Wideband LNB which Sky + can use.
Avatar for Simon70
Thanks GD1, so i could replace the LNB with something like this ?
@Simon70  The LNB you posted is a wideband, they are not compatible witb Sky + It needs to be Hybrid or Universal for Sky+ (Hybrid would allow Sky Q to be used again if you returned in the future).
Avatar for Simon70
I imagine i could buy a freeview box that would be compatable couldnt i ?
Yes, make sure it is wideband  Freesat and you'll be good to go 🙂
@Simon70  Most 4K Freesat (not freeview) boxes are able to use the Q LNB
