Discussion topic: No satellite signal on Sky HD box since rain pour yesterday
This message was authored by: MCHC
Error message on TV screen "No Satellite Signal, Contact Us". Called SKY, engineer unavailable for next 2 weeks. Is the fault with the Box or Dish ?
Re: No satellite signal on Sky HD box since rain pour yesterday
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
I am NeurodivergentFAQs: Sky GlassSky StreamSky GoSky Plus
@MCHC Possible that the rain has got into the cabling. You might find that a few dry days and it will start working again. If it does, keep the engineer appointment as the cabling would need replacing or it will happen again.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
