Discussion topic: No satellite signal on 4 of my 5 sky+ boxes
This message was authored by: RichieDavidDoyle
I have 5 sky+ hd boxes, Earlier today 4 of the 5 stopped getting a signal from the satellite dish. They have been off now for 12 hours and the boxes have stopped initializing so I can't even watch the recorded programs. @Skyhelp
Re: No satellite signal on 4 of my 5 sky+ boxes
What sort of LNB do you have?
What sort of distribution amp do you have?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am Neurodivergent Sky+HD  LG NanoCell TV  Xbox Series X  Raspberry Pi 5 (Debian Linux)
My F•A•Qs: Sky GlassSky StreamSky GoSky Plus
@RichieDavidDoyle
You may, also, need to be aware that whilst SKY still provide existing subscribers with subcriptions they no longer provide support for the boxes or other equipment
As you mention 5 boxes I suspect you do have some form of distrubution system rather than direct feeds from an LNB
As @Exiled-in-HH mentions I think it would help if you can give more details of your set up
