Discussion topic: No satellite signal hd box
This message was authored by: hinton132
Hi
My sky hd box is playing up, keeps saying no satellite signal keep rebooting still the same ,works for a bit then goes off.  Weather is fine , any suggestions,
Re: No satellite signal hd box
It's more likely to be a problem with your dish or cabling. If you have Sky Protect give them a call to request an engineer visit. If not, you'll need to engage a local satellite installer to come and take a look.
OR the box is starting to fail.... they are getting on a bit😉
